ROJEK PF 350 3200mm Panel Saw 3ph
720868
From £8,914.98 £7,429.15
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Enquire - contact us for a personalised quote
  • High quality European made industrial machine
  • 350mm diameter blade, 115mm depth of cut
  • 3,200 sliding table with telescopic cross cutting fence
  • Scoring blade for splinter-free cuts
The Industry 9 series machines from ROJEK are designed for hard, daily use. The high standard of engineering, design and materials make this panel saw an excellent choice for a professional joinery shop. The PF 350 is built with a precision ground cast iron table. It takes a 350mm diameter saw blade giving a depth of cut of 115mm (80mm@45).
The panel saw comes fitted with a 3,200mm sliding table allowing large sheet materials to be cut to size with ease. This package includes an outrigger roller to handle larger panels with ease. The scoring blade with its separate motor ensures a clean splinter-free cut every time. The standard equipment includes an aluminium sliding table 360 x 3200mm on steel round bars, mitre fence with protractor +45°/-45°, rip fence with micro adjustment, ripping stop, handle of sliding table, blade safety guard, scoring unit with separate motor, cam operated panel clamp.
There are also optional additional accessories, to further tailor the machine to particular needs. These include:
Digital indication of rip fence position, digital indication of cross-cut stop, table extension – width of cut 1500mm, precise angle adjustment 5°,10°, 15°, 20°, 22,5°, 30°, 40°, 45° (for cross-cutting fence), additional second outrigger with support leg, upper control panel, upper control panel with electric saw blade tilting and uplift – ELGO, electric saw blade tilting and uplift – ELGO, supporting profile of the frame, variable speed of saw blade; inverter (with motor 10,2HP).
The PF 350 is a high quality European made machine, built to last, and designed to be dependable with the industry user in mind. Our specialist consultants will be happy to discuss the ROJEK range with you; email sales@axminstertools.com or call 03332 406406.
Warranty 1 Year Warranty
