The ROJEK range is available with a variety of additional options and accessories which can be customised, with some variations held in stock. Please contact our Business Team via the enquiry form, email sales@axminstertools.com or call 03332 406406. Our specialist consultants will be happy to guide you through the range and tailor the machine to particular needs and requirements.
This machine can also be viewed in person at our High Wycombe store.
High quality European made industrial machine
Quality engineering, design and manufacturing
Contact our Business Team to discuss your requirements
The Industry 9 series machines from ROJEK are designed for hard, daily use. The high standard of engineering, design and materials make this surface planer an excellent choice for a professional joinery shop.
If space is available then having a dedicated surface planer saves a great deal of time. The Rojek RFS 410 planer is made to exacting standards and capable of producing accurate results time and again. The long precision ground cast iron tables and a long solid cast iron fence (no aluminium extrusion here) guarantee perfect results every time. The cast iron fence features a special tilting mechanism for bevel planing at exact angles. The fence is supported on rollers to make accurate adjustments smooth and easy. Accurate depth of cut adjustment using a large cranked lever under the infeed table gives perfect results, removing as much or as little timber as is required.
All ROJEK Industry machines can be supplied with options and upgrades to suit your individual requirements.
A wide range of optional upgrades and accessories offer the opportunity to tailor the machine to particular requirements.
Options include: - 4-knife HSS cutterblock, TERSA cutterblock, Spiral cutterblock, Upper control panel, 3-phase 7.5kW motor with upper control panel, Protection fence for thin material and Knife-setting gauge.
The RFS 410 is a high quality European made machine, built to last. Contact our Business Team to discuss your requirements. Call 03332 406406 or email sales@axminstertools.com.
