The ROJEK range is available with a variety of additional options and accessories which can be customised, with some variations held in stock. Please contact our Business Team via the enquiry form, email sales@axminstertools.com or call 03332 406406. Our specialist consultants will be happy to guide you through the range and tailor the machine to particular needs and requirements.
This machine can also be viewed in person at our High Wycombe store.
High quality European made industrial machine
Quality engineering, design and manufacturing
Contact our Business Team to discuss your requirements
Precision ground cast Iron table on 4 support pillars
The Industry 9 series machines from ROJEK are designed for hard, daily use. The high standard of engineering, design and materials make this thicknesser an excellent choice. If space is available then having a dedicated thicknesser saves a great deal of time. The RFT 630 thicknesser is designed for mass production. The overall construction is very solid to enable it to cope with the high demand of industrial usage.
The RFT 630 thicknesser is very easy to operate. At its maximum it can take 630mm wide x 300mm thick and remove up to 8mm with each pass. The precision ground cast iron table sits on four support pillars and features adjustable rollers for smooth throughput. Feed speed is easily adjustable from five to twenty metres a minute.
All ROJEK Industry machines can be supplied with options and upgrades to suit your individual requirements.
The wide range of optional upgrades and accessories offer the opportunity to tailor the machine to particular requirements.
Options include: - 4-knife HSS cutter block, TERSA cutterblock, spiral cutterblock, 3-phase 9,2 kW motor, segmented infeed roller, rubberised infeed /outfeed roller and knife setting gauge.
The RFT 630 is a high quality European made machine, built to last. Contact our Business Team to discuss your requirements. Call 03332 406406 or email sales@axminstertools.com.
