SCM C30G 4 Function Combination Machine - 230V
107718
From £7,739.98 £6,449.98
1 Review
Out of Stock
  • 4-functions: Saw, Spindle Moulder, Planer, Thicknesser
  • Features: Ease-of-use, flexibility, precision, safety
  • A perfect choice where workshop space is limited
A combination machine offers different functions in one compact and multifunctional unit. The SCM C30G 4-Function combination machine with all Minimax’s quality is an ideal choice for an ambitious home woodworker or light trade workshop. The C30G comes as standard with: ease-of-use, flexibility, precision, and safety. The C30G has three independent motors each dedicated to one of the functions and controlled separately. The machine tables are cast iron and mounted on a steel fabricated base unit. The fences are extruded anodised aluminium and are all fully adjustable. The C30G comes with a wheel kit. Even a small workshop where space is at a premium can accommodate this 4-function machine.
The saw offers a maximum cutting height of 90mm and tilts up to 45°. For crosscutting, the sliding table and aluminium fence provide a very accurate means for making square and angled cuts. The fence comes with a repeat stop.
The spindle moulder has a 30mm spindle with two speeds. The spindle has a capacity of 75mm in length. The recess in the table will accept tooling up to 145mm in diameter.
The planer has a 300mm wide by 1,200mm long table. The planer is fitted with a TERSA 3-knife block for a clean cut and easy changing and setting.
Thicknessing is a matter of raising the tables and relocating the dust hood. Timber up to 300mm x 200mm can be accurately dimensioned. The timber is fed by feed rollers at a fixed speed of 6 metres per minute.
An exceptionally useful machine if you have limited space.
Warranty 1 Year Warranty
5.00 1
