Tite-Fix Screw-Tite Compact Organiser (Pack of 460 Pozi Screws)
109394
109394
From £10.38 £8.65
2 Reviews
  • Buy 5 for £9.86 £8.22 each
  • Buy 10 for £9.35 £7.79 each
  • Buy 15 for £8.82 £7.35 each
In Stock - Ready to dispatch
  • Tri-Lock thread for fast start and high pull-out resistance
  • No need for pilot holes, use in softwoods and hardwoods
  • Self-countersinking for a clean flush finish
  • Reduced insertion torque for longer battery run time
  • High performance pozi PZ2 screws
  • Zinc and yellow passivated, high corrosion resistance
No need to waste time hunting for the right screw, it’s right here in this handy organiser case. The case contains 460 high performance Screw-Tite pozi driv screws in the most commonly used sizes.
Screw-Tite screws come with a number of advantages. Tri-Lock Threadform combines the benefits of twin and single thread in one screw. You get a quick and balanced start and finish with high pull-out resistance. No need to spend time drilling pilot holes. They can be driven into most materials without the need to pilot. Use with confidence in softwood, hardwood etc. These are high strength screws with correctly formed recesses especially suitable for cordless screwdrivers. The double-countersunk head has cutting edge ribs that ream and self-countersink for a clean flush finish. All screws PZ2, zinc and yellow passivated, includes full and partial thread.
Contents:
125 - 3.5 x 16mm
100 - 3.5 x 20mm
80 - 3.5 x 30mm
40 - 4 x 40mm
30 - 4 x 50mm
35 - 4 x 60mm
20 - 5 x 50mm
30 - 5 x 70mm
5.00 2
