The TA450 saw bench is built to last and become the reliable backbone of any busy joinery workshop. It is powerful and accurate. Its strength lies in its construction, precision engineering and use of fine quality components.
A large cast iron table mounted on a heavy duty steel cabinet provides maximum support and strength.
The saw spindle is powered by a high efficiency IE2 industrial rated braked motor and features large diameter saw flanges for blade stability. It runs in ‘sealed for life’ bearings mounted in a cast iron housing.
Rise and fall and tilt mechanisms are operated by handwheels at the front and side of the machine. Both are easily accessible.
The rip fence is a strong aluminium extrusion, allowing for Hi-lo working positions and for movement fore and aft in relation to the sawblade. It is fixed to a heavy duty cast iron mounting bracket for rigidity, and has integral micro adjustment. The bracket runs on a nylon roller, gliding easily and is supported by a 40mm diameter solid steel bar for rigidity. It gives 915mm capacity from the saw blade (an optional RH extension table is available to increase this to 1220mm).
