The SENCO AC12810 is a low noise, oilless compressor designed and built for trade and professional use in a workshop or on a job site. Portable, reliable and powerful, the SENCO AC112810 is ideal for use with staplers and nailers. This high-spec compressor delivers 80l/m or 2.38cfm of free air at 6bar, giving you plenty of scope for usable air tools. Reliable and robust, the SENCO AC12810 is quiet; at only 65dB(A), it will cause far less disturbance to your working environment compared to a standard compressor (average conversion level is around 65 dB(A)).
The AC12810 features a high quality, low revs motor and a twin cylinder compressing unit with a 10-litre tank. Oil free technology provides you with clean, oil-less air. Oilless compressors are low maintenance and produce less heat compared to other compressors. Reduced condensation reduces the chance of problems with air tools. In addition, less condensation means less frequent draining of the tank.
The SENCO AC12810 features a convenient handle and two wheels for easy portability. It comes fitted with female Euro air coupling.
