Shaper Up-Spiral Ball Nose Router Bit 1/4" Shank
- Ball nose cutter ideal for lettering and signage
- Solid carbide composition stays sharp longer
- Great results in a wide variety of materials
Shaper Up-Spiral O-flute Router Bit 3.175mm x 12.7mm 1/4" ShankFrom £39.00 £32.50
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price £69.97 £58.31 was £89.98 £74.98 Save £20.01 £16.67
The ball nose cutter is ideal for cutting channels, leaving a 3.2mm radius rounded bottom to the cut. It makes a good choice for lettering and signage. Made of solid carbide it is suitable for a wide variety of materials and specialty applications
The spiral upcut design lifts waste out of the cut, at the same time helping keep the Shaper down on the work surface. These solid carbide cutters ensure a very clean fast action, greatly reducing tearout and help ensure a smooth finish. The design gives a shear cutting action.
Overall Length: 63,5 mm (2.1/2")
Shank Diameter: 6,35 mm (1/4")
Cutter Diameter: 6,35 mm (1/4")
Cutter Length: 19,05 mm (3/4")
Geometry: Upcut, Spiral, Ball Nose
Material: Solid Carbide
D = Overall Diameter | 6.35 mm (1/4") |
EAN Barcode | 859790007450 |
X = Depth of Cut | 19.05 mm (3/4") |
International delivery is unavailable for this product.
