Shaper Woven Hose for Origin Router
109655
From £109.00 £90.83
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Smooth external surface prevents snagging
  • Smooth internal bore ensures maximum airflow
  • Highly flexible and durable
  • Antistatic reduces static buildup
  • 27mm/32mm tool connection
  • 2.5 metre length
With its smooth internal bore it minimises internal friction, which in turn ensures maximum airflow and suction. The hose is extremely flexible and with an equally smooth outer surface. Unlike traditional ribbed vacuum hoses, the Shaper hose will not catch or snag on a corner or the edge of your bench. The tapered 27/32mm connection fits snuggly in the Shaper’s extraction outlet, at opposite is 55/58mm taper for connection to your vacuum extractor. Made from antistatic material it prevents static build up caused by the waste passing through.
Length 2.5m.
