Shokunin Blade for Japanese Ryoba Saw - 210mm
105004
105004
- Replacement or spare Japanese saw blade
- Fits Shokunin 210mm Ryoba saw
- Double-edged; cross cut and rip cut
- Easy change, single screw fixing
Show more
Show less
A replacement or spare blade for the Shokunin 210mm Ryoba Japanese saw. These double-edged Ryoba blades are 0.45mm thick and 210mm long. Easily changed by simply loosening the locking screw on the handle, remove the old blade and replace it with the new.
Blade Thickness | 0.45 mm |
EAN Barcode | 5052511101771 |
Length of Blade | 210 mm |
Tooth Pitch \ tpi | 1.50 mm \ 17 tpi Crosscut Rip cut 2.5 mm - 3.9 mm \ 10 - 6.5 tpi |
