Shurtape FrogTape Multi-Surface Masking Tape
117007
From £8.17 £6.81
1 Review
Low Stock - Ready to dispatch
  • The only painter's tape with exclusive PaintBlock Technology
  • Prevents paint from bleeding by forming a micro-barrier along the edges
  • Results in the sharpest paint lines possible
  • Multi-surface for use on cured painted walls, wooden trim, glass and metal
  • 41.1m(133ft) rolls, 36mm width
FrogTape is a true innovation. Its super absorbent polymer along the tape's edge attracts the moisture in emulsion paints, creating a micro-barrier. The result is the sharpest lines possible, making touch-ups a thing of the past.
FrogTape Multi-Surface (green) is a medium adhesion painter's tape designed for use on cured painted walls (dried 3 days minimum), wooden trim, glass and metal. After application, it will remove cleanly from most surfaces for up to 21 days (or 7 days in direct sunlight).
For best results remove FrogTape immediately after painting. It is ideal for creating stripes and paint effects. Sold in 41.1m(133ft) rolls, 36mm width.
5.00 1
