Stabila 196-2-60 Level
- Rugged and rigid levels built for professional use
- Strong rectangular alloy profile with reinforcing ribs
- End caps are removable for measuring flush into corners
- Anti-slip pads, prevent level moving when held against a wall
- Rubberised hand-holes make for easier handling
- Milled upper and lower faces, equally accurate when used upside down
- Accuracy of spirit level: 0.029° or 0.5mm/m, length
Built for professional use, these high quality levels are an ideal choice for any trade. The body of the level is an extra rigid rectangular alloy profile with reinforcing ribs, providing high resistance to deformation. The protective end caps are removable for measuring flush into corners. The end caps incorporate anti-slip wall pads, which allow you to hold the level firmly against a wall with one hand without the risk of it slipping. A special coating protects the level against dirt, whilst rubberised hand-holes make for easier handling. Milled on its upper and lower faces the level is accurate in both normal and upside down positions. Accuracy of spirit level: 0.029° or 0.5mm/m, length: 60cm (24").
EAN Barcode | 4005069152338 |
Level Length | 60 cm (24") |
Model | 196-2 |
