Stabila 70-2 Combi Pack 30cm + 60cm + 180cm
102612
From ÂŁ83.40 ÂŁ69.50
2 Reviews
Low Stock - Ready to dispatch
  • Great general purpose levels
  • Accurate, lightweight and fast
  • Always accurate, work with confidence and speed
  • Large, clear, easy-to-read vials
  • Kit contents:
  • 1 X 70-2 1,800mm / 72" Level
  • 1 X 70-2 600mm / 24" Level
  • 1 X 70-2 300mm / 12" Level
  • 3 X Carpenter's Pencils
  • 1 X Key Ring Level
Whatever the project, this pack of three provides you with all the levels you’re ever likely to need. The two longer (1,800mm and 600mm) levels feature three vials each, two plumb and one horizontal. The shortest (300mm) level has one plumb and one horizontal vial. Accuracy is 0.029° or 0.5 mm/m in the normal working position. Also included are three very useful carpenter’s pencils and a handy level key ring.
Stabila 70-2 series are strong extruded aluminium alloy levels. The rectangular box section features an easy, clean, electrostatic powder coating and protective end caps. These levels are accurate and lightweight with easy-to-read vials. They are suitable for both light trade and home use.
Kit contents:
1 x 70-2 1,800mm / 72" Level
1 x 70-2 600mm / 24" Level
1 x 70-2 300mm / 12" Level
3 x Carpenter's Pencils
1 x Key Ring Level
5.00 2
