Stabila 96-2 Double Plumb Level
AX23385
AX23385
- Professional levels, precise and lightweight
- Rectangular aluminium box section
- Internal ribs for additional stiffness
- End cap stoppers
- One horizontal and two plumb vials
- Levels over 1,200 mm do not have milled surfaces
Show more
Show less
A lightweight, precise level made from rectangular aluminium box section with internal ribs for additional stiffness. The end caps, which are fitted with stoppers on one side to provide grip when the level is used vertically, can be removed for close-up work. The levels have one horizontal and two plumb vials. N.b Levels over 1,200 mm do not have milled surfaces.
Model | 96-2 |
