Stabila 96-2 Level Pack 60cm + 120cm + 180cm
This product is no longer available online or by phone. Unfortunately we are unlikely to receive any more stock.
- Pack comprises one of each: 600mm, 1,200mm and 1,800mm
- Stabila 96-2 extra strong double plumb ribbed box section levels
- Extra strong light metal rectangular profile with gripping ridges
- Removable end-caps are with anti-slip stops
- Accuracy: normal 0.5 mm/m = 0.029°, overhead 0.75 mm/m = 0.043°
A pack of three levels featuring Stabila’s 96-2 extra strong double plumb ribbed box section levels. These use an extra strong light metal rectangular profile with gripping ridges for the bodies. They have removable end-caps allowing better access into a corner. The end-caps are also equipped with well-proven patented anti-slip stops. Each level has two vertical vials, one horizontal vial and two milled measuring surfaces (1,800mm has non-milled faces). Measurement accuracy: normal position 0.5 mm/m = 0.029°, overhead measurement 0.75 mm/m = 0.043°. Pack comprises one of each: 60cm, 120cm and 180cm.
EAN Barcode | 4005069173791 |
