Stanley FatMax Deep Pro Organiser
- 10 removable storage compartments, transparent lid for quick view of contents
- Strong polypropylene construction; size: 446 x 356 x 116mm
- Waterproof seal to prevent water and foreign particles from entering
- Polypropylene handle with textured grip, 2 two metal latches
- Multiple organisers can be clipped together using the slide latches
The Stanley Deep Pro Organiser comes with 10 removable storage components allowing you to organise your smaller accessories for efficiency, inside and outside of the box. With the transparent lid you can easily view what is in your toolbox and where it is without the need to rummage through. With the waterproof seal you can be assured no water or foreign particles will enter. The organiser is also fitted with a textured polypropylene handle to give you a more secure grip and, with the heavy duty metal latches, you can be confident the toolbox will not accidently fall open. For easy transportation, the two metal side slide latches allow you to attach your organiser to another. Size: 446 x 356 x 116mm deep.
EAN Barcode | 3253561975189 |
Nett Weight | 2.13kg |
Overall L x W x H | 446 mm x 356 mm x 116 mm |
