These Compound Action Diagonal Cutting Pliers feature a dual pivot design giving 70% more gripping and cutting power than standard single pivot pliers. The dual pivot means they make any task that much easier. These cutting pliers allow you to cut copper or aluminium wires up to 2.5mm diameter effortlessly as well as cutting piano wire.
As with all FatMax these tools are designed for professional trades. They are made to be durable and make the job easier. The ergonomic handles have bi-material non-slip grips for comfort and safety. The jaws are high-carbon steel, heat treated and carefully ground to give a high level of performance.
