Stanley FatMax® VDE Insulated Screwdriver Set, 6 Pce
112825
From £28.87 £24.06
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
The Stanley FatMax® VDE Insulated Screwdrivers, which have VDE insulated tips individually tested to 10,000 volts and guaranteed to 1,000 volts. They are fitted with a soft grip handle that has been moulded directly to the bar to reduce fatigue and provide a virtually unbreakable bond. A heavy-duty plastic sheath running the length of the bar protects the user from live current. Contents: 3 x Parallel: 2.5 x 50mm, 3.5 x 75mm, 5.5 x 150mm. 2 x Phillips: PH1 x 100mm, PH2 x 125mm. 1 x Voltage Tester.
