NATGOZ tack cloths are most effective where dust particles are in the approximate range P240 to P600. NATGOZ is a pure, soft woven cotton gauze, approximately 500 x 750mm, folded in such a way as to give you 16 highly effective surfaces per rag. NATGOZ leaves no residue and only requires very light hand pressure across the surface.
Whether painting, varnishing or lacquering by brushing or spraying, the one thing that is certain to ruin your finish is dust. You might not be able to see it, but be sure it is there, just lurking on the surface waiting to spoil your chosen finish. Dust is an anathema, a Tack Rag is the solution.
With over 40 years of production, Tack Rags know a thing or two about removing dust. These tack cloths remove particles of dust, dirt and lint that would otherwise contaminate a surface you intend to finish. Wiping the dust, rather than trying to blow it off the surface, locks the dust away preventing it re-settling elsewhere.
