The Ultimate Router Base
109973
Special Price £104.99 £87.49 was £149.98 £124.98 Save £44.99 £37.49
1 Review
Low Stock - Ready to dispatch
  • Universal mounting holes to most routers and a huge variety of jigs and mounting configurations
  • The only off-set router base that accepts a template guide
  • Calibrated distances on two edges lets you make rough and finished reduction cuts with one set up, saving time and money
  • Provides more control and support, adds an extra level of safety
  • Plenty of room to custom mount your own router brand and accessories
  • Centre slot with metric and empirical ruler for circle and radius cutting
  • Removable centre disk for safe and stable cutting when using large-diameter router bits
  • Side slots for an adjustable fence or bushings for curved edgework
  • Bushing and holes for self-centring mortise cuts
  • Crosshairs for spindle centre alignment
  • Annotated distances to the spindle centre, so no need to measure bit to edge for fence set ups.
  • Manufactured from high-grade anodized aluminium making it strong and lightweight, with tight tolerances
  • Show More
Packed with features, the patented Ultimate Router BaseĀ® System is perfect for any professional or hobbyist woodworker who wants to create straight cuts as well as complex shapes, circles, curves and inlays quickly and accurately.
The design adds surface area to your router base for greater stability, safer operation and more controlled cutting. Produce accurate, precisely matched curved joinery and dead-centred inlays over a seam easily, every time. High machining tolerance avoids slop or wiggle sometimes found between a router base and standard template guides. The patented feature of calibrated distances on two edges lets you make rough and finished reduction cuts with just one set up, saving time and money.
The extra-large, optimally sized offset extended router base is made from 8mm thick high-grade anodized aluminium, which is strong and lightweight and eliminates flexing. Plus, it's currently the only off-set router base on the market that accepts a template guide.
The Ultimate Router Base System is designed and developed by master craftsman, woodworker, artist, sculptor, teacher, author, tool designer and YouTuber Scott Grove. Scott designed the system after being frustrated by the limitations of other router bases on the market; the result is a system packed full of features like no other.
Save time, money and add new dimensions to your creations simply and safely by turning your handheld router into the ultimate tool in your workshop. Exclusive to Axminster Tools in the UK, The Ultimate Router Base System will be the only router base you ever need.
5.00 1
