Thor 712N Nylon Hammer - 38mm, 650g (23oz)
152270
152270
- Online exclusive
- Chrome plated zinc head
- Two screw-in nylon faces which are designed to be replaced when worn
- Used as a multi-purpose striking tool in most assembly applications
- 38mm head diameter and 650g in weight
Show more
Show less
Chrome plated zinc head with two screw-in nylon faces which are designed to be replaced when worn. Two hard white nylon faces. Used as a multi-purpose striking tool in most assembly applications including engineering, furniture, shopfitting, partitioning, double glazing and injection moulding operations.
EAN Barcode | 5012936117122 |
Hammer size \ weight | 650 g (23oz) |
