Titebond Solvent Free Construction Adhesive
AX20345
AX20345
- Blend of polymer emulsions, for interior and exterior use
- Suitable for wood, metal, plastics and some rubbers
- Solvent free, use with polyurethane and polystyrene
- Setting time 6-24 hours
- Tube 296ml(10oz) & 215mm length(excluding nozzle)
Show more
Show less
A solvent free adhesive designed to give a strong bond between wood and most other building materials, hence the name. Excellent for the fitting of applied decorative mouldings and panels and a wide range of materials as diverse as wood, metal, masonry and types of plastic, plasterboard, polyurethane and polystyrene applications. Some clamping or bracing may be necessary for heavier items whilst drying. For use in a skeleton gun. Tube 296ml(10oz) & 215mm length(excluding nozzle)
Adhesive Type | Blend of polymer emulsions |
Setting Time | 6-24 hours |
Suitable For | Wood, Metal, Some Plastics, Masonry, Rubber, Leather |
Usage | Interior or Exterior |
