Tormek SJ-250 Japanese Waterstone - 250mm
702802
702802
- Delivers an extra fine surface finish
- Excels at sharpening hand tools where a minimum of steel removal is needed
- 4,000g ideal for carving tools, scissors, knives, plane irons and bench tools
Show more
Show less
The Tormek SJ-250 Japanese Waterstone delivers an extra fine finish. It excels at sharpening hand tools where a minimum of steel removal is needed and a superior surface finish is demanded. The stone is 4000 grit and is ideal for carving tools, scissors, knives and well maintained plane irons and bench tools.
Bore Size | 12 mm |
EAN Barcode | 7392485001195 |
Grit | 4,000 |
Model | SJ-250 |
Wheel Diameter | 250 mm |
Wheel Width | 50 mm |
