Tormek T-4 Original Sharpening System & Hand Tool & Woodturner's Kits
720883
720883
From £999.98 £833.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Compact, high quality sharpening system with 200mm wetstone
  • Sharpen your plane irons and chisels with a perfectly square edge
  • Sharpen hand tools, knives, scissors, woodturning and woodcarving tools
  • Comprehensive kit of 6 jigs for sharpening common hand tools
  • Comprehensive woodturner's sharpening jig set
  • NVR switch, providing safety in the event of an interruption of power
  • SP-650 Stone Grader and AngleMaster included
  • Strengthened housing for improved sharpening results
  • Solid zinc, precision machined top incorporating the handle
  • 8 year warranty (5+3)
  • Show More
A cut above the rest
The most advanced water cooled sharpening systems available, Tormek machines allow you to sharpen your tools to the finest edge.
The innovative design is appreciated worldwide for its unbeatable versatility, accuracy and ease of use
The T-4 Original offers the same precision and stability as the larger models but with a compact design. Perfect for home and hobby use, or professionals with limited space.
The ultimate package for woodworkers and woodturners
This T-4 package comes complete with the HTK-906 Hand Tool Kit and TNT-808 Woodturner's Accessory Kit. HTK-906 is a comprehensive kit of six different jigs ideal for sharpening hand tools around the workshop and home. TNT-808 includes jigs for sharpening woodturning tools plus a tool rest and setter, honing wheel, protective cover and tuition manual.
Sharpen all your edge tools
Ideal for sharpening chisels, knives, scissors, and smaller tools such as woodturning and carving tools. Even complicated shapes such as fingernail turning gouges, spoon carving gouges and oval skew chisels with a radiused edge are easily sharpened with this user-friendly machine.
Key features
Longer tool life
The Tormek wet-grinding method leaves a polished, burr-free edge without overheating the tool. The water acts as a coolant, meaning the temper of the steel is not affected whilst you sharpen, which significantly extends the life of your tools.
Fast and safe
Worn steel particles, produced when shaping, are washed into the water trough. This means only a fraction of steel is removed, which makes it a quick job. It also means the air is kept clear of grinding dust and no potentially hazardous sparks are produced.
Quality and performance
Powder-coated zinc top houses vital functions like the motor, main shaft and sleeves for the universal support mounts. This design forms a strong foundation which guarantees minimal play and provides the stability needed for precise shaping, sharpening and honing.
Exact replication
Patented universal support mounts (bars), which guide all jigs and accessories, can be mounted either horizontally or vertically providing the ideal set up for any tool or user. The mounts are held in two strong, steel sleeves and the secure locking design allows for tighter tolerances. Providing, even a beginner, the control needed for repeatable results.
Full control
Powerful, maintenance-free, industrial motor (AC) ensures minimal speed loss even under heavy load. At the low speed, you have full control of the sharpening and remove no more steel than is necessary - making your tools last longer.
Easy to set
The micro-adjust feature, with acme thread and scale, together with the AngleMaster means it's easy to precisely set your edge angles for repeatedly consistent results.
Efficient and versatile
SG-200 Original Grindstone has been developed to combine efficient steel removal, smooth surface finish and have a longer life. By using the SP-650 Stone Grader you can alternate the surface of the grinding wheel from a 220g coarse cut to a 1,000g fine.
Cleanest edges
The sharpening process is finished by honing and polishing the edge on the leather wheel. The equivalent of 2,500-3,000g can be achieved. This leaves your tools with a razor-sharp edge so you're ready to produce your best work.
Invest in quality and performance
With a wide range of jigs and accessories available the Tormek T-4 can be customised to suit your sharpening needs, making it the ultimate sharpening system. Investing in a Tormek machine means you'll never have to put up with dull tools again.
Not sure which Tormek machine suits your needs?
Our guide makes it easy to compare the Tormek T-8 and T-4.
Discover the ultimate sharpening solution with the Tormek T-4 Original Sharpening System, now available with the HTK-806 Hand Tool Kit and TNT-808 Woodturner's Kit. This compact, high-quality system is designed to provide precise and consistent sharpening for a wide range of tools, including knives, scissors, chisels, and woodturning tools. The Tormek T-4 features a robust construction with a stainless steel shaft and a powerful motor, ensuring long-lasting performance. The included HTK-806 Hand Tool Kit and TNT-808 Woodturner's Kit offer versatile sharpening options, making this system perfect for both professional and home use. Achieve razor-sharp edges and maintain your tools in top condition with the Tormek T-4 Original Sharpening System.
Tormek T-4 Water Cooled Sharpening System
The Tormek T-4 features a zinc cast top incorporating the machine's key components: the main shaft, Universal Support and motor assembly, which results in superb accuracy. Two sleeves hold the Universal Support in the zinc cast top, this along with the locking device and tight tolerances guarantees perfect results every time.
The T-4 is ideal for sharpening cabinet making hand tools, knives, scissors and woodcarving and turning tools. It comes supplied with two useful accessories, the first of which is the SP-650 Stone Grader that can be used to keep the stone cutting efficiently as well as changing the surface from a (220g) coarse cut to (1,000g) fine. The equivalent of 2,500-3,000g can be achieved on the leather wheel. The second is the AngleMaster, an adjustable device used to set the correct angle for grinding plane and chisel blades. Magnets on the reverse side of the AngleMaster mean that it is easy to store it conveniently on the steel machine plate.
Also supplied is the unique Tormek Handbook, where all the information that is required to shape, sharpen and hone your tools to perfection can be found. The T-4 uses a powerful, industrial AC motor and the shaft supporting the wheels is made from corrosion resistant stainless steel. It also includes the Tormek Handbook.
8 year warranty (5+3) Tormek extended warranty of 5 years + 3 extra years upon registration.
Tormek HTK-806 Hand Tool Kit
Packed in a high quality storage case with an opaque lid and foam insert the HTK-806 is a comprehensive kit of 6 jigs for sharpening common hand tools. The jigs enable you to sharpen a wide range of tools such as axes, scissors, long chef’s knives, short bladed knives, carving and butt chisels, pocket knives and garden shears.
The Tormek HTK-906 contains the following Tormek jigs: KJ-45 Short Knife Jig, KJ-140 Long Thin Knife Jig, SVX-150 Scissor Jig, SVS-38 Short Tool Jig, AX-40 Axe Jig and SVM-00 Small Knife Holder.
Tormek TNT-808 Woodturner's Accessory Kit
Packed in a second high quality storage case, the TNT-708 is a comprehensive woodturner's sharpening jig set. The TNT-708 innovative Tormek tool set for woodturners contains everything you need to shape and sharpen all turning tools. The jigs give you complete control over the sharpening process. The jigs ensure you are able to reproduce and repeat your preferred bevel angles and tip profiles time after time.
The Tormek TNT-708 set includes the following Tormek jigs and accessories: SVD-186 Universal Gouge Jig, SVS-50 Multi-Jig, SVD-110 Torlock Tool Rest, TTS-100 Angle and Setting Gauge, LA-120 Honing Wheel, MH-380 Protective Cover, and tuition manual.
Here's the full list of everything you get in this ultimate kit;
• Perfect for sharpening hand tools, knives, woodturning tools etc
• 200mm diameter stone with stainless steel shaft
• Compatible with a huge range of Tormek jigs
• New 8 year warranty (5+3)
• Kit contains:
• KJ-45 Centring Knife Jig for general and short knives
• KJ-140 Wide Centring Knife Jig for long chef’s and filleting knives
• SVX-150 Scissor Jig for scissors and shears
• SVS-38 Short Tool Jig for carving and butt chisels
• AX-40 Axe Jig for axes and hatchets
• SVM-00 Small Knife Holder for carving knives and pocket knives
• HTK-00 Storage Tray for Hand Tool Kit
• TC-800 Storage Case
• Kit contains:-
• SVD-186 Universal Gouge Jig
• SVS-50 Multi jig
• SVD-110 Torlock Toolrest
• TTS-100 Turning Tool Setter
• LA-120 Honing Wheel
• MH-380 Protective Cover
• Tuition manual
• Includes quality storage case
For more tips on sharpening please see Tormeks YouTube channel.
Warranty Tormek 8 year Warranty, 5+3 (Registration Required)
