Trend AIR PRO MAX TH3 Air Powered Respirator APF40
- Protects; lungs, eyes, face, and head to level APF40/TH3
- Motor and filter supplies constant clean fresh air
- Clear, mist free, all round vision at all times
- No loss of protection for workers with facial hair
- Suitable for spectacle wearers
- Ergonomic design, well balanced and comfortable
- Highly efficient HEPA filter
- Flip-up visor
- Li-ion Batteries give up to 8 hours run time
- Fully adjustable headband
Take your PROtection to the MAXimum with the Trend PRO MAX APF40 (AIR/PRO/M). This positive pressure, powered respirator offers industrial rated; lung, eye, face, and head protection all in one. The PRO MAX protects against fine airborne particles, flying debris, and head impact; with the option of hearing protection by adding clip-on ear defenders.
Positive pressure fan driven, filtered air means there is never a problem with misting, fogging or steaming up. Thus ensuring the optical class 1, face shield provides all round vision and full protection at all times. The face shield flips up so you inspect your work without removing the unit .
No face fit required, whether you wear spectacles or sport a full beard the PRO MAX APF40 offers the same high level of protection. A fully adjustable padded head harness along with the soft elasticated face seal ensure complete comfort even when worn for extended periods. The twin Li-Ion 3.6V batteries can deliver up to 8 hours run time on a single charge.
The PRO MAK APF40 is fully serviceable and comes with a set of watertight bungs allowing full immersion in water for cleaning. A peel-off visor overlay is included to prevent the visor from scratches.
Technical:
Respiratory protection EN12941:1998+A2:2008, Protection level TH3.
Assigned Protection Factor APF40.
Eye protection BS EN 166:2002.
Optical class 1.
Mechanical strength B - High speed particles, medium energy impact.
Field of use 3 - Liquid droplets and splashes.
Airflow min. 170 l/min.
Airflow [Fully Charged]: 220 litres per minute.
Headband adjustable from 54cm to 64cm.
2 x Li-ion removable and rechargeable batteries.
8 hour runtime on full charge.
Low battery warning.
Unit weight: 1,481g.
