Trend Concealed Decking Jig DK/JIG
- Install your decking without visible fasteners
- 50° hardened screw guide to create hidden fixings
- Improves decking appearance and prolongs decking life
- Built-in board spacers for drainage and expansion
- 90 - 150mm adjustment feature to suit a range of boards
- Quick-release clamping arm to secure the deck quickly
- On-board storage for the driver bit
Tite-Fix Deck-Tite 4.5 x 50mm Pozi Screw Tub Net-Coat - Pack of 500Special Price £13.98 £11.65 was £18.28 £15.23 Save £4.30 £3.58
Tite-Fix Deck-Tite 4.5 x 63mm Pozi Screw Tub Net-Coat - Pack of 450Special Price £14.98 £12.48 was £19.98 £16.65 Save £5.00 £4.17
Improve the appearance and prolong your decking life with the Trend Concealed Decking Jig. Install your decking without visible fasteners with ease; the 50° hardened screw guides allow you to create a hidden deck fixing, whilst the built-in board spacers create accurate 3.5mm, 4.5mm, 5.5mm or 6.5mm gaps between boards, for drainage and expansion. It has an adjustable quick clamping feature to suit board widths 90 - 150mm, suitable for an extensive range of standard or non-standard boards.
The jig has a quick-release clamping arm, which allows you to secure the jig to the decking board quickly, for faster installation. It has on-board storage for the driver bit and includes a hex shank Roberson no.1 bit driver.
EAN Barcode | 502765408585 |
Model | DK/JIG |
