UJK Compact Angle Square
- On the go, quick angle reference marker
- Accurate and versatile square
- British made from brushed stainless steel and Aluminium
- Includes quick guide angles of 22.5°, 30°, 60°, and 67.5°
- Durable, accurate, and sleek design
- Ideal for repetitive mark making
- Available in metric and imperial sizes
- Anti-corrosion properties and super tough construction
Axcaliber Four Flute Tenon/Milling Cutter Long Shank 1/2"From £90.18 £75.15
The UJK Compact Angle Square is the ideal, on-the-go, quick angle reference marker. This handy square is an accurate and versatile tool, manufactured in Britain from brushed stainless steel and aluminium it’s both durable, accurate and sleek.
Designed for use with a 3-8H pencil, the UJK Compact Angle Square is great for repetitive mark making. It not just the 90° and 45° angles it features, inside, you'll find quick guide angles of 22.5° , 30°, 60°, and 67.5 °, allowing you to mark common angles quickly and repetitively making it an essential tool for many projects. Available in metric and imperial sizes.
With its anti-corrosion properties and super tough construction, the UJK Compact Angle Square is built to last. Whether you're a professional or a DIY enthusiast, this tool is a must-have for precise and efficient work.
