UJK Air Wedges - Mixed Shapes (Pkt 3)
- Inflatable shims with dozens of uses
- For fitting, fixing or levelling; slimline, slides into a 2mm gap
- Hand operated for controlled inflation
- Hard-wearing, non-marring material
- 1 x Slim: size 100mm x 140mm, lift 2mm to 45mm
- 1 x Square: size 160mm x 145mm, lift 2mm to 55mm
- 1 x Wide: size 260mm x 140mm, lift 2mm to 85mm
Ambersil Corrosion Inhibitor SpraySpecial Price £13.03 £10.86 was £17.38 £14.48 Save £4.35 £3.62
Package deal comprises 3 x UJK Air Wedges (1 of each size)
Slim: size 100mm x 140mm, lift 2mm to 45mm, maximum lifting weight 100kg.
Square: size 160mm x 145mm, lift 2mm to 55mm, maximum lifting weight 180kg
Wide: size 260mm x 145mm, lift 2mm to 85mm, maximum lifting weight 180kg
Versatile doesn’t even begin to describe the UJK Air Wedge. Whether you are fitting, fixing or levelling, the UJK Air Wedge makes the job a great deal easier. The UJK Air Wedge is good for lifting something up, pushing something into position or forcing things apart. Made from highly durable, non-marring material and with triple welded seams, the UJK Air Wedge is virtually indestructible. An internal stiffener makes it easy to insert the UJK Air Wedge into a narrow gap. By gently squeezing the bulb, you can make controlled, fine adjustments. Press the release valve to deflate the Air Wedge.
Initially marketed as a tool for holding window frames in place prior to fixing, it is indispensable in many other situations. When fitting a door, a UJK Air Wedge underneath one corner makes it easy to align the hinges. For levelling kitchen appliances or cabinets, use a UJK Air Wedge to lift a fridge or washing machine etc while you make adjustments.
EAN Barcode | 5052511114917 |
