UJK Compact Router Table Fence
- Fence to fit UJK compact router tables
- Adjustable in-feed and out-feed fences
- T-slot for accessories at the top and front of the fence
- Graduated scale provided along top of fence
- Transparent 63mm dust port for efficient extraction
UJK 10mm Aluminium Router Table Insert c/w Universal BaseFrom £183.58 £152.98
UJK Off Set Bars for Router TablesSpecial Price £7.88 £6.57 was £21.38 £17.82 Save £13.50 £11.25
The UJK Compact Router Table Fence is a beautifully made, single piece aluminium section supplied with a transparent 63mm dust port for efficient extraction from above the table. Provision is made for the fitting of guards and accessories with a T-slot at both the top and front of the fence. An adjustable transparent guard is included for your safety. Adjustable scales are provided for attachment at either side of the table and the fence is attached to these locking into place in the required position. A scale is also provided along the top of the fence with the zero position at the centre. Adjustable infeed and outfeed fences attach to either side of the aluminium section and the central aperture can be opened and closed according to the diameter of the cutter in use. Comes complete with the side channels. Fence measures 789 x 90mm.
EAN Barcode | 5052511072064 |
