UJK Extraction Outlet for Pocket Hole Jig
- Developed for the UJK Pocket Hole Jig
- Extraction outlet can be simply fitted
- Attach a vacuum for extraction, o/d 42mm, i/d 35mm
UJK Storage Case for Pocket Hole JigSpecial Price £13.98 £11.65 was £34.98 £29.15 Save £21.00 £17.50
Especially developed for the UJK Pocket Hole Jig, this extraction outlet can be simply fitted so that you can attach a vacuum for extraction. Outlet diameter: outside 42mm, inside 35mm.
EAN Barcode | 5052511066650 |
Model | UJK Pocket Jig Extraction Outlet |
