Veritas Metric Bevel Setter
202376
From £31.88 £26.57
3 Reviews
In Stock - Ready to dispatch
  • Stainless steel
  • Allows a sliding bevel to be set at any angle from 1° to 60° in 1/2° increments
  • Can be used in conjunction with a bevel to check existing angles
  • The reverse has common dovetail and polygon angles
  • Metric Graduations
This stainless steel bevel setting tool allows a sliding bevel to be set at any angle from 1° to 60° in 1/2° increments. Similarly it can be used in conjunction with a bevel to check existing angles. The blade is 75 x 180mm, and the graduations etched for permanence. The reverse has common dovetail and polygon angles.
5.00 3
