Veritas Miniature Router Plane
952975
From £54.58 £45.48
  5. Half Star
23 Reviews
In Stock - Ready to dispatch
  • Useful plane for hardware installation, fine inlay or intarsia work
  • 3.2mm wide A2 tool-steel blade, hardened to HRC 60-62
  • Machined stainless steel body with ground and lapped sole
  • Fine screw feed mechanism controls blade depth
  • Weight 55g, width 75mm
  • Supplied in an embossed, French-fitted presentation box
This 75mm wide router plane not only looks like its full-size counterpart, it works like it too. Comfortable to hold and manoeuvre, it is ideal for hardware installation, fine inlay or intarsia work. It comes with a 3.2mm wide A2 tool-steel blade (hardened to HRC 60-62), positioned inboard for standard use or outboard for true bullnose work. The carefully machined stainless steel body has a ground and lapped sole. The sole encircles the blade for maximum registration to a workpiece and to bridge recesses for stability on narrow stock. The knobs are hardwood. A fine screw feed mechanism sets blade depth, whilst a knurled clamping knob secures the blade. Weight just 55g, supplied in an embossed, French-fitted presentation box.
4.70 23
