Veritas Shop Rule - 300mm Metric Only
109687
From £19.68 £16.40
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Great workshop rule, 63mm wide
  • Easy to read laser-etched scale
  • Strong anodised aluminium extrusion
  • Thin edge avoids parallax errors
  • Scales on both edges L to R & R to L
Designed to offer just about everything you’ve wished for in a great workshop rule. 300mm long and 63mm wide, with the zero at the end and scales on both edges L to R on one edge and R to L on the other. These are much more than a plain old rule. The solid anodised aluminium extrusion is finished matt black, which highlights the contrast to the laser-etched markings. The edges are tapered to avoid parallax errors, underneath the edge a slight ‘foot’ raises the edge minutely, ensuring any markings will not be smudged as the rule is moved away. Ridges along the central part of the rule offer a firm grip and prevent your fingers from slipping. The wide profile and square cut end make it easy to measure accurately with the rule butted against a machine fence for instance. A hanging hole is provided for safe storage.
A rule you will reach for often.
