Veritas Shop Rule - 450mm Metric Only
- Great workshop rule, 63mm wide
- Easy to read laser-etched scale
- Strong anodised aluminium extrusion
- Thin edge avoids parallax errors
- Scales on both edges L to R & R to L
Axminster Workshop Self Healing Cutting Mat - A1 (594 x 841mm)From £24.38 £20.32
Designed to offer just about everything you’ve wished for in a great workshop rule. 450mm long and 63mm wide, with the zero at the end and scales on both edges L to R on one edge and R to L on the other. These are much more than a plain old rule. The solid anodised aluminium extrusion is finished matt black, which highlights the contrast to the laser-etched markings. The edges are tapered to avoid parallax errors, underneath the edge a slight ‘foot’ raises the edge minutely, ensuring any markings will not be smudged as the rule is moved away. Ridges along the central part of the rule offer a firm grip and prevent your fingers from slipping. The wide profile and square cut end make it easy to measure accurately with the rule butted against a machine fence for instance. A hanging hole is provided for safe storage.
A rule you will reach for often.
EAN Barcode | 0722356027691 |
Graduations | Metric Only |
Manufacturer Part Number | 05N04.23 |
Rule Length | 450 mm |
