Veritas 4 Piece Super-Hard Milled Scraper Set
476257
- Hardened to HRC 48-52 to hold an edge longer
- Edges are carefully milled to a square, sharp 90°
- Prepared edges save time and effort of filing and stoning
- 50 x 150 x 0.4 & 0.6mm for fine work
- 60 x 150 x 0.8 & 1mm for heavier stock
- 1mm scraper suitable for paint removal
Show more
Show less
Whereas most cabinet scrapers are sheared from spring steel and hardened to HRC 38-42, these Veritas scrapers are harder (HRC 48-52) and hold an edge longer. Their edges are carefully milled to a square, sharp 90°. The set includes four thicknesses: for fine work, 0.4mm(0.016") and 0.6mm(0.024") thick, each 50mm x 150mm(2" x 6"); for heavier work, 0.8mm(0.032") and 1mm(0.042") thick, each 60mm x 150mm(2.3/8" x 6").
EAN Barcode | 722356001721 |
