Whitehill Steel 150mm Replaceable Tip Groovers
AX824723
AX824723
- Replaceable tip groovers
- Three different sizes from 8mm to 12mm
- Maintain exact cutting diameter - conventional groovers change diameter each time they are sharpened
- Cutting spurs on tipped groovers
- 150mm diameter
- 30mm bore
- Complete with tungsten tips
Whitehill TC Tips for 150mm Replaceable Tip Groovers - 8mmFrom £2.68 £2.23
Show more
Show less
Replaceable tip groovers in three different sizes 8mm to 12mm. The advantage of the disposable tips is that they maintain the exact cutting diameter irrespective of how many times you change the tip, unlike conventional groovers that change diameter each time they are sharpened. Tipped groovers have cutting spurs on both sides of the cutter and in most materials produce exceptionally clean grooves or rebates. 150mm diameter 30mm bore complete with tungsten tips.
