Woodcut Tools Bowlsaver Max 4 Light Guide
- Plan before you cut
- Takes the guesswork out of setting the Bowlsaver Max
- Light guide shows the path the cutter will take
- Quick and easy to set up and use
Axminster Professional Stainless Steel Metric Rule - 300mmFrom ÂŁ3.38 ÂŁ2.82
Axminster Professional Forged Flat Bar Clamp 200 x 80mmFrom ÂŁ14.98 ÂŁ12.48
WoodSpur Torx Head Wood Screw Assortment (1,500 Pieces)From ÂŁ29.98 ÂŁ24.98
Watch where you’re going, the Woodcut Tools Bowlsaver MAX Light Guide shows you the path the coring blade will take, Before you begin cutting. The light guide is a great help when it comes to the best from your blank. The MAX light Guide is for the three bladed Bowlsaver. Setting up and coring is much easier when you can plan the cut exactly beforehand. the Bowlsaver Light Guide makes it easy to establish where the blade is going to cut the wood blank.
The Light Guide has a post, which attaches to the pivot bolt of the Bowlsaver. It has an arm that holds a light pen positioned in line with the cutter. The Bowlsaver guide has three holes, one for each blade.
EAN Barcode | 9421905382533 |
