Z-Poxy Epoxy Resin
From £29.28 £24.40
53 Reviews
Please note: You must be 18 or older to buy this product.
  • Suitable for Wood, Metal, Plastics, Cloth, Leather Rubber and Ceramics
  • Interior/Exterior use, gap filling with shock resistant characteristics
  • Resists fuel, oil, many chemicals and solvents
  • 118 ml (4 fl.oz) each, resin and hardener
  • N.B. To buy this product you must be aged 18 years or over.
Epoxy Resin is one of the strongest and most durable adhesives available and suitable for a wide range of applications. Z-Poxy 5 Minute is a quick setting two part epoxy resin giving a clear, tough, permanent bond to wood, metals, fibreglass and many plastics. It has excellent gap filling and shock resistant characteristics in a glue line that doesn't shrink and is resistant to fuel, oil and many chemicals and solvents. The non-reversible chemical curing takes place in just five minutes, which in most cases eliminates the need for clamping. Z-Poxy 30 Minute has all the attributes of the five minute version but with the added benefit of a longer open or working time, essential in some assemblies. The slower cure also gives the further benefit of an even stronger bond and enables the casting of small components and the making of epoxy putty when compounded. Both packs are 8 fl.oz (4 fl.oz resin; 4 fl.oz hardener). Like most chemical curing products they are sensitive to temperature and humidity affecting the cure times. Good working conditions are therefore essential to gain the best results.
4.80 53
