Zipbolt Micro Rail Bolt Connector
104386
104386
- QT16.600 micro handrail connector, for joining narrow or thin handrails end to end
- Also used for 90°° handrail to newel joints
- Housing size only 19mm diameter, zinc finish, sold singly
Show more
Show less
Perfect for joining thin or narrow handrails end to end or a horizontal handrail to a newel post. The open channel housing allows you to drop the housing over the shaft for easy thread engagement. Screwing in the threaded section is simple using a spanner. The mechanism requires only a 19mm diameter housing for best results (15mm minimum) and a 4mm hex key for tensioning.
EAN Barcode | 5060111546809 |
