Zipbolt Mini KD Straight Connector
504437
504437
- QT12.720 Mini KD straight connector, angle range of 80 - 180°
- Size 6 x 90mm, suitable for 16-25mm board thickness
- Housing size 25mmø x 12.5mm, insert size 21 x 10mm
- Requires 4mm hex bit for tensioning; 6mm hex bit for insert
- Zinc finish, sold singly
Show more
Show less
An ideal for the fast secure fixing of furniture components. The open channel housing allows you to place the housing over the shaft, engaging the thread and automatically positioning the housing at the right height. Suitable for board thicknesses of between 16-25mm, the mechanism requires a 25mm diameter housing and a 4mm hex bit for tensioning.
EAN Barcode | 5052511120222 |
