Zipbolt Worktop Connectors 170mm with Zipclips (Pkt 3)
107520
107520
- Fast, strong and secure connectors for 28mm and thicker worktops
- Addition of Zipclip acts like a third hand
- Zipclips make installation quicker and easier
Show more
Show less
These 170mm Zipbolt connectors are intended for use in joining worktops 28mm and thicker.
The speed and ease of joining worktops with Zipbolts is even faster and easier with the addition of a Zipclip. The Zipclip, acts as your third hand. It simply snaps onto the Zipbolt, and its flexible retaining wings grip the sides of the routed slot, holding the Zipbolt in place. This is a pack of three Zipbolt connectors and Zipclips. Zipbolts are compatible with most worktop jigs. A 5mm hex bit will be required for tensioning these connectors.
Connector Length | 170 mm |
EAN Barcode | 5060111546939 |
