A great set of detail carving tools from Japan. The steel has excellent edge holding properties, precisely ground and honed ready for use. The chisels contained in the set are hollow ground for ease of sharpening. Nicely shaped hardwood handles fit comfortably in the hand and, adding a nice touch, is a flat area on the handle to stop them rolling off of the bench. Set contains 8mm skew chisel, 8mm curved flat chisel, 6mm vee tool, 6mm gouge, 3mm veining tool.
Set 5 Piece
EAN Barcode 4952631800053
