Tenon Saws
  • Stanley FatMax Tenon Saw 11tpi - 300mm
  • Veritas Dovetail Saw 14tpi - 230mm Veritas Dovetail Saw 14tpi - 230mm
  • Jack Irwin 3055 Tenon Saws Jack Irwin 3055 Tenon Saws
    £9.78 - £10.57
    This selects the Length of Blade of the variant Length of Blade
  • Veritas Small Crosscut Saw 16tpi - 235mm Veritas Small Crosscut Saw 16tpi - 235mm
  • Veritas Fine-Tooth Dovetail Saw 20tpi - 235mm Veritas Fine-Tooth Dovetail Saw 20tpi - 235mm
  • Veritas Crosscut Carcass Saw 14tpi - 275mm Veritas Crosscut Carcass Saw 14tpi - 275mm
  • Veritas Rip Cut Carcass Saw 12tpi - 275mm Veritas Rip Cut Carcass Saw 12tpi - 275mm
  • Axcaliber FineLine Gent's Saw 15tpi - 250mm Axcaliber FineLine Gent's Saw 15tpi - 250mm
  • Veritas Tenon Saws Veritas Tenon Saws
    £126.98
    This selects the Tooth Pitch \ tpi of the variant Tooth Pitch \ tpi
  • Axcaliber Fineline PTFE Tenon Saws Axcaliber Fineline PTFE Tenon Saws
  • Veritas Miniature Rip Tenon Saw Veritas Miniature Rip Tenon Saw
  • Stanley Clamping Mitre Box & Saw
    £23.65
  • Stanley Saw Storage Mitre Box with Saw
    £15.97
Tenon Saws
Tenon saws are precision back saws designed for cutting accurate joinery in woodworking, cabinetmaking and furniture making. Featuring a rigid spine for added stability and fine teeth for clean, controlled cuts, they are ideal for cutting tenons, shoulders, cheeks and other traditional woodworking joints. Favoured by joiners and hand-tool woodworkers, tenon saws deliver the accuracy needed for high-quality joinery and fine craftsmanship. Browse the range to find tenon saws suited to furniture making, cabinetmaking and precision woodworking projects.
