Ice Bear Japanese Extra Fine Gent's Saws
- For cabinetwork, modelling, instrument makers, dolls house makers
- Rip teeth, fine 28tpi, cuts on the pull stroke
- 120mm blade has a kerf of 0.2mm, 160mm blade has 0.3mm kerf
A true Gent's saw is a small dovetail saw, with a straight turned handle. Intended for joints in cabinetwork, they also have uses for modellers, musical instrument makers, dolls house makers etc. These Japanese examples feature rip teeth and cut on the pull stroke, offering you the best of both worlds. These saws require no set, both are 28tpi. The 120mm long blade has a kerf of 0.2mm the 160mm blade has 0.3mm kerf. Fine saws for fine work.
Tooth Pitch \ tpi | 0.91 mm \ 28 tpi |
