Ice Bear 5 Piece Japanese Oire Nomi Special Alloy Chisel Set
- Special high carbon alloy tough steel similar to HSS
- Manufactured to withstand use on particle board and knotty timbers
- Edge hardened to approximately HRC 68
These chisels, available only in a set of 5, are made from a special alloy steel, similar to high speed steel, laminated to a softer steel base. The harder edge steel, approximately HRC 68 will better withstand continual use on particle board and knotty timbers. Sharpening procedure is the same as for other Japanese chisels. Sizes are 9, 15, 24, 30 and 36mm.
EAN Barcode | 4560272501286 |
- Standard Delivery* - Free
