Ice Bear Japanese Super Fine Saw 42tpi - 55mm
- A saw for precision work, kerf of only 0.16mm, with 42tpi
- Blade 55mm long by 15mm deep
- Cuts on the pull stroke, teeth have no set
- 185mm (7.1/4") long overall
This is a saw for workers in wood where precision is paramount, such as musical instrument makers. A unique example of a Japanese saw, it has a kerf of only 0.16mm. The blade is 55mm (2.1/8") long and 15mm deep with extremely fine teeth at 42tpi. It cuts on the pull stroke, giving better control when working with such a fine blade. The teeth have no set. It is 185mm (7.1/4") long overall.
Blade Thickness | 0.16 mm |
EAN Barcode | 5052511023264 |
Kerf | 0.16 mm |
Length of Blade | 55 mm |
Overall Length | 185 mm |
Tooth Pitch \ tpi | 0.60 mm \ 42 tpi |
- Standard Delivery* - £1.99
