Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Jet JWDS 1632 Drum Sander
Code: 103731
  • Sandsmart™ control continuously monitors the sanding load
  • Conveyor bed parallelism adjusted by turning a simple dial
  • Conveyor system smoothly pulls the workpiece through the sander
  • Relative depth measurement for easy depth gauging
  • Efficient dust extraction with a ducted drum hood
  • Stand features a large footprint to increase stability
  • Show More
£1,319.50 (£1,099.58 Ex. VAT)
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We'll aim to despatch your products the same day when you order before 4pm, Monday to Friday.
  • Standard UK (5-7 day) - free
  • Premium UK (next day) - from £6
  • International - available
Find out more
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Jet 2 Year Warranty
The newly designed Jet 1632 drum sander has several innovative features to help make finishing sanding an accurate and effortless task.
N.B. These sanders are used for fine finishing, they are not intended to be used as a thicknesser or with coarse abrasive for significant stock removal. In all instances, they are intended to be used with planed and thicknessed material.
The major focus on this machine has centred around the conveyor table, which now features a simple dial to adjust the parallelism with the sanding drum, including a lock bolt to keep your settings secure.
The motor drive system now pulls the work through the machine rather than pushing, creating a smoother flow, reducing the chances of marking. This arrangement allows you to sand work pieces as short as 60mm. Jet's patented Sandsmart™ system has been fitted, which monitors the sanding load and automatically controls the feed speed to prevent aggressive sanding burning the work.
The sanding drum has improved access to the abrasive securing clips, while the hood has been redesigned to improve dust extraction. The whole frame has been redesigned to give a smoother look, but also to increase the rigidity and accuracy. The drum depth adjusting handle has a scale to allow relative depth adjustment to be set for each project. Both drum motor and conveyor motor controls are grouped conveniently together for easy control.
The sander is supplied with a floor stand with rubber feet, which has a wide footprint for stability and is pre-drilled for optional castors. A worthwhile accessory is the extension table set (103813), which almost doubles the working surface area for extra support. A single 100mm dust extraction outlet is provided, efficient dust extraction is vital with these machines, please make sure your system is adequate. This machine will suit many small furniture or musical instrument makers looking for a precise finishing sander.
Information Downloads
Promo
This product is on page 72 of the Axminster Tools & Machinery 2019/20 Catalogue.
Specification
Specification
Abrasive Roll Width 76 mm
Dust Extraction Outlet 100 mm
Feed Speed 0 to 3 m/min (var)
Model JDS 1632
Nett Weight 71 kg
Overall L x W x H 1,007 mm x 508 mm x 1,269 mm
Power 1.1 kW
Rating Trade
Sanding Drum Diameter 127 mm
Sanding Thickness Min\Max 0.8 mm to 75 mm
Sanding Width Double Pass 812 mm
Sanding Width Single Pass 406 mm
Table Size 456 mm x 420 mm
Voltage 230 V
Drum Speed 1,720 rpm
Min Extraction Airflow Required 750 m³/hr
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
