Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 3-5 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Jet JWL-1221VS Woodturning Lathe
Code: 505073
  • Fully cast iron construction with an extra wide bed, superbly stable
  • Exceptionally wide range of spindle speeds, 60-3,600rpm
  • Innovative ratchet style belt tensioning system, perfect every time
  • Conveniently located motor controls and speed DRO
  • 24 integrated indexing positions and spring loaded spindle lock
  • Smooth transition between forward and reverse for easy control
  • Show More
Save £284.50
NOW £715.00
Normally £999.50
(£595.83 Ex. VAT)
Out of stock
Sorry, this product is no longer available.
See Alternative Options
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Jet 2 Year Warranty
The Jet JWL1221VS is different to every other lathe in the Jet range. The whole lathe has been designed to make the woodturning experience better by focusing on control. As with all other JET lathes, this one is made from cast iron, but the bed width is much wider than is usually found on machines of this size. This gives great support to the tool rest holder, which also stays exactly where you clamp it even under the heaviest loads. The spindle is supported by heavy duty bearings and is quietly driven by a 745W DC variable speed motor via a three step, multi V belt system. All of the motor controls are very conveniently located together; the speed control, spindle speed digital readout and forward/reverse selector all come naturally to hand. The tall, rigid tailstock has an ACME barrel lead screw with 64mm of travel, the barrel and headstock spindles have 2MT tapers. Camlocks on both tailstock and toolrest holder allow easy positioning just where you want them. To help keep things tidy there are tool and cable storage fittings on the bed, keeping those essential tools within easy reach. The lathe stand has a built-in storage tray plus wide feet for stability. This is without doubt a very fine small lathe.
N.B. The distance between centres will vary and be dependent on the type of centres or accessories used.
Information Downloads
Promo
This product is on page 329 of the Axminster Tools & Machinery 2019/20 Catalogue.
Specification
Specification
Distance Between Centres 520 mm
Headstock Taper 2 MT
Max Diameter over Bed 318 mm
Model JWL-1221VS
Nett Weight 50 kg
Overall L x W x H 1,003 mm x 229 mm x 445 mm
Power 745 W
Rating Trade
Spindle Thread M33 x 3.5 mm
Tailstock Taper 2 MT
Voltage 230 V
Lathe Speed 60 - 3,600 rpm (var)
Tool Post Diameter 16 mm (5/8")
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
