More deals added in
Have you clocked our Christmas Countdown deals?
JSP Force™10 Typhoon™ Full Face Mask With Visor
From £89.98 £74.98
  • Full face mask combines respiratory and face protection
  • Padded for extra comfort over prolonged use
  • Fully adjustable 5-point suspension harness
Customers Also Bought
JSP Force™ 10 Typhoon™ Full Face Mask With Visor
Enjoy an excellent fit with this extremely lightweight, easy to maintain full face mask with panoramic visor. The web-like structure of the harness cradles the users head for complete comfort.
PressToCheck™ Compatible
The Force™10 Typhoon™ is compatible with both JSP Classic filters and the PressToCheck™ filters which allow you to instantly check you have the correct seal every time you wear your mask.
Typhoon™ Exhalation Valve
Designed to reduce breathing resistance, heat and moisture build up, the unique Typhoon™ valve can be used with the same performance under very low temperatures.
Panoramic Impact Visor
The optical class 1 visor conforms to EN166.B offering impact protection at speeds of up to 270mph (tested using a 6mm ball bearing). This respirator comes complete with a replaceable peel-off visor protector to prolong its life.
Optimised ergonomics
Extensive research has distinguished the world’s 5 most common facial shapes. Using this information, JSP has digitally optimised the design of the Force™ Typhoon’s™ face seal to maximise wearer compatibility.
The JSP Force™10 Typhoon™ is a lightweight, easily maintained full face mask with a panoramic visor and Class 3 heavy-duty filter connections.
Using extensive independent research into human face shapes, JSP has been able to refine the design for a comfortable fit with an effective face seal. Made from a durable thermoplastic rubber, the mask will fit most face shapes. The 5-point suspension harness and quick release buckles make it easy to adjust. The mask moulds to the shape of the face and padding provides extra comfort. It is available in 2 sizes (M or L).
The optical Class 1 visor conforms to EN166.B impact protection (tested with a 6mm steel ball bearing travelling at 270mph). The completely clear panoramic visor maximises light levels within the mask giving optimum visibility. The visor has anti-mist and anti-scratch coating as standard and comes complete with a replaceable peel-off visor protector.
The unique Typhoon™ valve has very low breathing resistance, which in turn reduces heat and moisture build-up within the mask. The Typhoon™ valve allows you to breathe comfortably without fatigue.
The Force™10 Typhoon™ is compatible with both JSP Classic filters and PressToCheck™ filters. Using PressToCheck™ filters allows you to check that you have the correct seal every time. The Force™ 10 offers flexibility for many applications, providing protection against particulates, many gases and vapours.
Disassembly, cleaning and maintenance are effortless with replacement parts available if necessary. JSP Force 10 respirators are reusable. For convenience, they can be easily stripped, cleaned, maintained and reused for an indefinite period of time. Replacement filters whilst not indefinite, last far longer than single use disposable respirators. JSP recommend 1-3 days for high use, 3-5 days for medium use and 28 days maximum for light use.
Conforms to EN140 optical class 1 EN166 B (impact) EN 136 (class 3)
An initial face fit test is recommended.
  • Panoramic anti-mist, anti-scratch with impact protection
  • Typhoon valve breathe comfortably without fatigue
  • Filters available with low profile angle design
  • Order filters separately, dependent on required usage
  • EN140 optical class 1 EN166 B (impact) EN 136 (class 3)
    4.50 10
