Kapro 995 Vulcan Level
- Available in 60cm, 90cm, 120cm, and 180cm lengths
- Reinforced aluminium frame with ledge profile for better grip
- Dual-view vertical vial for easy, neck-friendly readings
- V-groove base for secure placement on pipes and curved surfaces
- Wall grip feature prevents slipping and surface damage
- Ergonomic soft-grip handle for all-day comfort
- ± 0.5 mm/m accuracy for professional-grade precision
The Kapro 995 Vulcan Level is built for professionals who value accuracy, durability, and ease of use. Its reinforced aluminium frame features a unique ledge profile for enhanced grip and control, even in tough working conditions. With two finely milled faces and a V-groove for secure placement on pipes and curved surfaces, it’s the perfect tool for plumbing, insulation, and general construction work.
Equipped with three solid acrylic shockproof vials—including Kapro’s patented Plumb Site® Dual-View™ vertical vial—you get clear, neck-friendly readings without twisting or bending. The ergonomic biomaterial handle offers a soft, comfortable grip, while the wall grip feature keeps the level steady without damaging surfaces.
Available in four sizes to suit every job: 60cm, 90cm, 120cm, and 180cm.
Model | Vulcan |
